Needed 3510 owners manual
   / Needed 3510 owners manual #1
M. Lowes
I have recently bought a used 3510 with back hoe and loader. I would like to have an owners manual. I have been looking on the Branson website and have come up short.
I have an extra single hydraulic line from the rear.
Just wondering what this does.
   / Needed 3510 owners manual #2
I "THINK" the single line is the odd man out (extra) with the backhoe and hydraulic lines attached. When you disconnect the backhoe this extra line will couple into the female so you dont deadhead your pump. The little male terminal (where BH female attaches) will be left to out and need to be covered (you need to make this change when the engine is OFF). If things seem weird or your engine is laboring after you make your change shut the tractor off and check your hoses for the correct connections.
I have taken the backhoe off this past weekend. I was very pleased how fast it removed. I removed the one line from the backhoe to the single line on the tractor. Coupled the two lines that run beside the rear wheels. Capped off the single line and they rear lift arms raised. So I assume I have this right.
   / Needed 3510 owners manual #4
sounds right. Good luck and please keep us posted.
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2015 Ford Transit Van (A50323)
2015 Ford Transit...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 Nissan Murano SUV (A50324)
2018 Nissan Murano...
