Need your help
   / Need your help #1
Wayne County Hose
Veteran Member
Wayne County Pa.
Massey Ferguson model 85, Allis-Chalmers WD-45
What I need is the following, your tractor make and model, and the max psi and gpm flowing out to your backhoe. I also really need these figures for some mini-excavators too. Thanks for your help, Andy.
   / Need your help
Anybody? I'm ordering a cylinder tomorrow for something I'm trying. If it works, this attachment will be lower priced that anything out there, simpler, and be far less work than anything currently available. I need pressures and gpm figures so I can get a good match of cylinder speed and power.
   / Need your help #3
2001 Kioti DK 35.
Tractor puts out around 7.8 gal/min and 2400 PSI.
The relief valve for my Rhino 85 backhoe is set at 2150 PSI.
   / Need your help
DK35vince said:
2001 Kioti DK 35.
Thank-you, this is a very popular tractor and model. Exactly what I need. Thanks again, Andy.
I need more, and hopefully a mini-excavator or two.
   / Need your help #5
Kubota L5030HSTC
9.8gpm
max system pressure is around 2600
I also have the Rhino 85 but I do not know the relief setting on that.
   / Need your help #6
JD 350B - 23 gpm, 2350 psi
ASV -100 - 38 gpm, 2750 psi hi flow, 20 gpm on low
JD 310 - 28 gpm, 2750 psi
Still trying to figure out how to add a diverter to the 350. KennyD offered to help, but i can't get the schematics to upload :(
   / Need your help #7
John Deere 4300 with a 48 backhoe - 9 gpm at 2500 PSI
   / Need your help #8
B7100HST-D, "new style" from the 90s
1710 PSI
3.1 GPM
I&T shop service manual says these numbers are correct for the following models.
B5100D & E
B6100D & E
B6100HST-D & E
B7100D
B7100HST-D & E
   / Need your help #10
JD 5225 13.9gpm 2883 PSI
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
