Need YM2000 ignition key
   / Need YM2000 ignition key #1
gclark94560
Bronze Member
UCLA - Upper Corner of Lower Alabama (Lanett)
Zen Noh/Yanmar YM2000, green
Hi All!
Anyone have any spare ignition keys for a YM2000. Probably the same as many other 1970s Yanni keys. It has one tumbler cut and a 30 stamped on it.
Hoye says they are sold out and can't get them.
Anyone got a spare? :eek:
   / Need YM2000 ignition key #2
I believe your friendly JD dealer will have the appropriate key. Just don't ask for a Yanmar 2000 key. I think (if I remember correctly) you need to ask for a key for a JD 850. It will be the correct key. My 2000 has been running a JD key for four years!
   / Need YM2000 ignition key #3
yep its an 850 JD also works in my fx28.
   / Need YM2000 ignition key #4
Just another point on the curve, my neighbor's key for his JD 750 works in my YM2220 - and vice versa. Don't know if the 750 key is the same as the 850, but ...
   / Need YM2000 ignition key #5
It is.
   / Need YM2000 ignition key #7
The local JD dealer sold me an 850 key that was supposed to work on my YM2000 and it did not. I've not tried the 750 but I will now....
Thanks,
   / Need YM2000 ignition key #8
There was an extensive post on this a while back. There are 2 types of keys. One cut on both sides and the other just cut on one side. There were photos of the keys in the post. My YM1700 has the double sided type. Do a search and look at the pics to see which type you have.
   / Need YM2000 ignition key #9
My local keyshop made a duplicate key (double sided) for my F18D using what he said was a stock Harley Davidson key blank.
   / Need YM2000 ignition key #10
2012 International ProStar Sleeper Cab Truck Tractor (A48081)
2012 International...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
2018 Ford Fiesta SE Sedan (A48082)
2018 Ford Fiesta...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2015 Chevrolet...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2013 Ford Escape S SUV (A48082)
2013 Ford Escape S...
