Need Wheel Weights
   / Need Wheel Weights #1
corelokt308win
Hello all,
I am looking for rear wheel weights to fit my TL2100F.
I am also looking for, if unable to find the weights, inner-tubes to fit the rear wheels so as to be able to put calcium in them.
   / Need Wheel Weights #2
I made a braket that used two lug bolts to hold it. I used piece of pipe welded to the center of the braket. I then slide 50#bar bell weights over the pipe and use a bolt to hold them on. You can add 100 to 150# on each side about as cheap as any way I have found yet. They can be taken off if you need to pretty easy too.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
Has charger with it. (A51694)
Has charger with...
