Need washers for studs that are that go with the nuts to torque down on the head...
   / Need washers for studs that are that go with the nuts to torque down on the head... #1
michaelballew
GA
ym1700
Im needing to find a place to buy a washer that goes under the torque nut for tightening down the head. Hoye tractor didn't have any so I may be out of luck.
   / Need washers for studs that are that go with the nuts to torque down on the head... #3
Go to your local NAPA store. They stock and sell them all the time. They are a one time item. You replace them any time you take the bolts or nuts off. Used many places besides head bolts, they are designed to even out the pressure all around the nut or bolt so torque is applied evenly.
Ron
   / Need washers for studs that are that go with the nuts to torque down on the head... #4
124450-01240
   / Need washers for studs that are that go with the nuts to torque down on the head... #5
Fredricks # HBW-4450 P.17 Eng, and Cooling.
   / Need washers for studs that are that go with the nuts to torque down on the head... #7
Buy Gr8 washers at TSC of the proper OD....~$4.60/ pound. Drill ID to suit... Total Cost ~ $0.50
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
378646 (A51573)
378646 (A51573)
RHINO SE8A SHREDDER (A52472)
RHINO SE8A...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
