Need tractor for deer food plots
   / Need tractor for deer food plots #1
scrimshaw33
Bronze Member
JD 4520 w/ cab and FEL
I've never owned a tractor and never used one except for the low powered riding lawn mowers.
I've researched that the best horsepower for my 100 acre farm will be around 45-48 horsepower (a good strength to get things done--will be planting food plots for deer, moving trees and brush, bushogging, cutting grass).
Am looking at the New Holland, John Deere, and Kubota somwhere around 45 hp with a frontloader.
Originally wanted the more compact 30-35 hp but from research sounded like the power wouldn't be enough.
Thoughts on tractor brand and hp?
   / Need tractor for deer food plots #2
I use mine for the same purposes, on my 300 acre hunting property. I plant food plots, maintain and create roads, clear trees and brush to make new shooting lanes, bush hog, etc. I have a M 6800 Kubota (68 hp) and find it ideal. You want 4WD, loaded rear tires, and implements. Moving trees is what takes power and weight, where as bush hogging does not. I highly recommend a grapple on the front (for moving trees and chain sawed debris, fallen trees etc.) Next is a heavier duty rotary cutter, especially if you use it in the woods to make new paths or lanes, such as a Woods Model 720. Cutting grass doesn't take a heavy duty whereas cutting sapplings and thick brush does. After trashing a regular duty after 4 years of hard use, I upgraded to a beefier one and like it. Then get a box blade for moving dirt and grading roads. And lastly a disc harrow, again the heaviest you can afford. A cheap 3 pt. hitch spreader speeds up fertilization, whereas I spread my seed by hand with a good chest type spreader for more control. Then make or buy something to drag to level the plots and cover the seed. That's all I use and feel I have everything covered. I think this sized tractor is ideal for what I do
   / Need tractor for deer food plots #3
You are going to be doing a lot of ground enguagement work, so you will want more of a ag utility tractor rather than a compact tractor. The weight of the tractor will mean as much as the HP in accomplishing your tasks. The heavier the tractor the more traction and stability. You will also want ag R1 tires over the industrial R4's. Good luck!
Thanks so much! HCJ, do you just use the disc harrow for your food plots or do you also have something like a plow to break the ground? Thanks for both of your guys help.
   / Need tractor for deer food plots #5
you looking for new or used?
if used.. a ford 4xxx series.. or 5xxx series should give you more than enough hp.
soundguy
would the New Holland tc33da work for me--4 WD, hydrostatic and diesal?
   / Need tractor for deer food plots #7
I have 300 acres of old farm land of which about half is wooded and the other half is fields which haven't been farmed since the sixties. I'm doing all of what you are doing plus maintaining a half mile of road. I have a JD 3720 w/cab, JD 4320 OS, and a Kubota M8200 w/cab -- bought all new and all are very good tractors. The JD 4320 is the workhorse of the three. Even though it's the newest (1.5 yrs), it's got the most hours on the meter because it's great for most work. In fact, I was telling my wife that if I went down to one tractor I would sell all three and get a JD 4720 w/cab. The 4720 is the same as the 4320 with more hp. Just my $0.02.
However, IMHO, you can't go wrong with any of the brands you are considering. Good luck.
   / Need tractor for deer food plots #8
I have been using TC40 DA for foodplots about 3 years now. I work about 8.5 acres. Hardest work I have is discing since I cannot plow my rocky soil. I can pull medium duty 6 ft disc no problem, although the rocks prevent deep penetration. If your soil is better with less rocks, the TC33 may be marginal in power.
   / Need tractor for deer food plots #9
Good question!! For years, we used our 20" x 20 disc Leinbach harrow (after bush hogging the plots) When the ground is wet from rain and relatively soft, it works pretty good, but still takes multiple passes. Our problem has been that when we want to plant in early September, it seems never to rain when we need it to, so that has been a major problem. The ground is rock hard and the disc just rolls along. Of course, some of this depends on your soil type. Here in upstate S.C., we have varied soil, some good river bottom, some clay, and a fair number of rocks.
This year, I bought a used three bottom turn over or "moldboard" plow. I also bought a two bottom which had no "trip protection" whereas the 3-bottom has shear pin protection. I trashed the two bottom snagging rocks but the 3 bottom works absolutely great (still shear some pins but that's an easy fix). This has really helped to use before the disc.
So to prepare an existing plot, we bush hog it close, (round-up helps but I don't have a sprayer), plow it (one pass, goes quickly), disc it 3 or 4 passes, then drag it with a home-made drag to level it out (We pull this with a vehicle). Then broadcast seed by hand and do a fast one pass drag to cover the seed. Then fertilize (either before or after seeding). We usually plant a wildlife mix (wheat, rye, oats, clover, peas) because it's cheap and works well. The more exotic blends are more expensive and our deer seem to like what we plant just fine. We do these steps over several weeks as time (and our wives) permit.
I agree with the previous post that an Ag type tractor would be better than a compact, and I don't feel all the "bells and whistles" are really necessary. Just a good heavy, powerful tractor in the 60 or 70 hp range would be all you ever need. Brands are just a matter of opinion. I like my Kubota, but have never used anything else.
Where are you located? How many food plots do you plan? Does the land need cleared and graded first? If so you may want to hire a dozer to speed things up. We did this is some places.
I will warn you. Tractors and implements are additictive!! Good luck in your search.
Thanks guys, it is addictive. Am anxious to use one.
I have a 100 acres in central NC. Clay soil though not real rocky. Some wet parts near ponds and creek. I think I'll use a front end loader to remove trees and brush and will definitely need something for bush hogging, planting food plots and tractor rides in the fall for the kids.
I have 50 acres of woods which are mature and will be cutting many to allow some small undergrowth, might use the tractor to help clear some roads and tear through the 20 yo growth after chainsaw work.
Am going to divide the 50 open acres (fields) so that I have more smaller food plots. I had the 50 open areas planted in soybeans this year so fescue is gone and should give me a good start and open pallate for whatever i want to do next year.
Am debating growing some pines to break up the fields which grow fast year vs letting nature take it's course and let old field succession take place for several years, burning or cutting it and letting the process start all over again to create cover for the deer.
Ideally adn the main reason I'm wanting to purchase a tractor is to plant food plots like the last poster and mainly the same mix as you with primarily clover (I agree--stay away from those bags of seed with the bucks on them, generic works just the same!), and maybe some corn for cover b/t food plots.
UNKNOWN  500BBL WHEELED FRAC TANK (A45046)
UNKNOWN 500BBL...
2018 Dodge Charger Sedan (A42744)
2018 Dodge Charger...
2019 Bobcat T740 Two Speed Compact Track Loader Skid Steer (A42742)
2019 Bobcat T740...
2019 KENWORTH T3 SERIES (A45046)
2019 KENWORTH T3...
Gravely Atlas JSV3000 AWD Utility Cart (A42744)
Gravely Atlas...
2008 Chevrolet Box Van (A42021)
2008 Chevrolet Box...
