You said "pump" - before it was a motor. I'd assumed your friend would use tractor remotes to power the bale unroller. If so, check out this
http://www.eaton.com/ecm/idcplg?Idc...eleased&Rendition=Primary&dDocName=DEV_216691
Look on page C-1-5, the upper chart is for their version of the 8.59 Cu.In/rev but without the agri-splined pto shaft. (third row down, third from the right is 3000 psi @ 1 gpm. Check the bottom of the chart for a guide to what the numbers are.
Near as I can tell, at 1gpm and 3000 psi, that motor would develop 3330 inch pounds, /12 would equal 277.5 foot pounds of torque at 3 rpm. (20 seconds per revolution) -
Realistically, the surplus hydraulics version seems to be rated a bit lower, but I'd expect it still to be around 200+ foot pounds of torque. Picture 100 pounds on the end of a 2 foot bar - unless there are frozen bearings involved, I'd think this would be enough.
With a 1:1 ratio, you would NOT want full flow thru the motor, just full pressure. So a flow control would be needed to slow down the bale (else centripetal force would unroll that bale REALLY quick :confused2:
So, are we still talking about a motor, or will friend be using a separate pump, or??!? Steve
