Need to move a tree
   / Need to move a tree #1
Halifax
usa
Ford
The house I'm buying has a very skinny driveway, and I'll need to widen it and make some parking spaces.
There is a ~10ft tall ornamental tree that will have to be moved.
I have no idea what it is, and if I will kill it when trying to move it with my Ford 575D backhoe.
Here is a picture of what the leaves look like, and the seed pods that hang from the tree:
What kind of tree is it?
   / Need to move a tree #4
Well I dont see a photo, but as a rule, the roots of a tree extend the distance that the limbs extend. If you can dig out a circle as large as the limb diameter, you will be good to go. The chances are pretty good that if you go half the distance and get a good deep root ball it will live with regular watering. Anything less is a gamble. A 10 foot tall tree should not be a problem to relocate with a large back hoe. Likely one deep scoop will uproot all you need. I think I would dig out a bucket deep on all four sides, staying away from the tree the needed distance, then run the bucket under it and lift it out.
   / Need to move a tree #5
Some trees have wide shallow root system, some have a very deep thick tap root.
Try to figure out which type this is, the deep tap root ones are fussy, if you cut off that deep tap root they get very unhappy. the shallow type if you keep watered after moving they eventually regrow their wide shallow root system. In general.
--->Paul
   / Need to move a tree #6
Please remember time of year. We transplant frequently with a 70% success rate. You are at the very end of a transplant season... Best to transplant when it the tree is dormant.
2004 Chevrolet Silverado 2500 Service Truck (A53422)
2004 Chevrolet...
24008 (A53422)
24008 (A53422)
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2015 Ford F-350 Cab and Chassis Truck (A53422)
2015 Ford F-350...
