Need to learn about beginner tractor user
   / Need to learn about beginner tractor user #1
vivancoj
Stone Mountain, GA
None
My wife and I are in the process of buying a house on a 3.7 acres of wooded land. It has a creek bed which right now is empty.
Lots of trees different sizes and lots of thick brush. I am a three year beekeeper with 7 hives at the current time. I am also
a gardening for vegetables lover. Initially I thought about buying a brush cutter from the ones that Home Depot rents and sales
after 3 years of use. I need to clear some areas for my vegetable garden and take down some small trees as well.
At age 74 while still strong I dont have the know how and probably the strength to take on this task with a small machine. A friend
suggested I buy a used tractor with a bucket, and a bushog.
I am at a loss as to what to get, as prices, etc......I would like to get one with a trailer so I can loan it to my son who has a 7 acre
spread.
Any suggestions??????????????
Thanks,
Jos
   / Need to learn about beginner tractor user #2
Welcome to TBN :)
I moved your thread to the Buying/Pricing/Comparisons Forum.
   / Need to learn about beginner tractor user #3
A 35-40 HP tractor with a medium to heavy duty bush hog will cut sapling size trees 3-4" in diameter if you can ride them over with the tractor the BH will cut it but it will leave a stubble and stump . You might be able to push them over and uproot them with a front end loader on the tractor depending on soil conditions. I have also did the same with a drawbar on the 3 point hitch with small trees just back into them with the drawbar to ride them over which will sometimes uproot or at least loosen up the roots so you can use a chain and pull them up with the 3 point hitch. Of course the larger the tractor the more lift capacity you have. Some of these actions takes some tractor driving skills to do safely so only attempt what you feel comfortable with
Check out Tractorhouse.com for prices on most new and used tractors and equipment. This will give you a good idea on what is out there and general pricing. If buying used especially from internet sites,watch out for scams and remember if it sounds too good to be true, it most likely isnt. With all the info out today, almost anyone can get a realistic value for what they are selling and price it accordingly.
   / Need to learn about beginner tractor user #4
Thanks,
Jos
Yes, get your son involved and you guys enjoy thinking, looking and planning. Once your money is out of pocket, the looking ends, and it is a pretty fun part of the adventure. I googled craigslist stone mountain ga. and Atlanta came up. Then under "farm and garden" I searched "loader" with no quotes. I know nothing about this tractor, looks a bit big. Enjoy
MF 253 4wd loader
   / Need to learn about beginner tractor user #6
Many thanks.
Sure! Start looking at you local Craig's list, and at you local newspaper. Consider how big it needs to be, etc. Looking is FUN, and I generally look at least once a week. It gives you something motivating to do as you do your study of what would suit you best.
   / Need to learn about beginner tractor user #7
spread.
Thanks,
Jos
For what you are contemplating:
A. you do not need a small tractor
B. you do not need a bush hog
c. you do not need a front end loader
Save your self a ton of money and work and hire a bulldozer for 3 hours work.
The small dozer will dig the trees out for you and then you can burn them
up in the winter if you have snow cover.
Land clearing is a very expensive and dangerous thing for the beginner (dont ask)
You will spend less time hiring a dozer than having to deal with a blown cooling system
from saplings getting shoved into the radiator or breaking a cooling fan.
After the dozer is done the ground will be flat as a pancake and you can
spray round up and woody brush killer and let it work and then till it.
You can spend the money you would waste on a used tractor for new 13 horse
BCS 2 wheel tractor with a rotary plow to break ground after the dozer is done for
much less money and the BCS 2 wheel tractor can be used for other jobs as it can
accept a big herd of attachments.
I want you to suceed and not fail.
_______________________________________________________________________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
   / Need to learn about beginner tractor user #8
c. front end loader
Save your self a ton of money and owrk and hire a bulldozer for 3 hours work.
BCS
It doesn't look bad at all. A man ought to try one to make sure it will suit him.
Here are the Georgia distributors.
BCS Dealer Locator
It all depends on what a man wants to do, and this would fit into what you broadly suggested you would like to accomplish.
We had a 2wd tractor when I was a kid, but the 4 wheeled tractor got more work..but we had 50 acres. In the garden, the 2 wheel tractor and the tiller got plenty of use. Our 2 wheel tractor has a turn plow, a spike tooth harrow, a disk harrow, a planter, cultivators and a trailer (and a couple of things I am likely forgetting.) Our 2wd tractor would "make a man out of you" since when the clutch was thrown (with one hand) the handlebars would immediately try to plummet toward the ground. This modern tractor seems to have worked some of that out, so it may be far nicer.
If trees are much of an issue, getting a dozer over to knock that out does make good sense.
   / Need to learn about beginner tractor user #9
c. front end loader
This is good advice, especially the dozer part. One down side though is you don't get to own a tractor!
   / Need to learn about beginner tractor user #10
Well, on one hand, 3 1/2 acres is just barely enough land to turn a 35hp tractor with loader and cutter around on. On the other, if you're retired and doing the work yourself is just part of the experience, tally ho.
If I you, I'd look for a 10-15 year old Massey Ferguson, Ford/New Holland, or Long tractor. Might (most likely) not have 4wd but many will have power steering, shade, and loader. The 850/950/1050 John Deeres are fairly common but most don't seem to have loaders for whatever reason. MF 230/231 are great little tractors in this range. You may be able to even find a similar Kubota of the same time period for a little more.
Tractors? Well they are both like buying a used car and extremely unlike buying a used car at the same time. For people around tractors, you understand this. For those who have not been, you won't. I wish I could express it better but I really can't think of way to do so.
Splash 10ft 2,100 Gallon Water Tank Truck Body (A52377)
Splash 10ft 2,100...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
More info coming soon! (A50322)
More info coming...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
