Need to Know
   / Need to Know #1
Roy Z
Stuart, Ok
1994 John Deere 2650
I have a 1994 John Deere 2650 European Tractor. I was pressure washing a few weeks ago and broke into several pieces a 1/4" tubing that comes off of the Hydraulic Oil Cooler Reservoir, there are two lines, one goes to the Hydraulic pump just below the Reservoir, but the other I'm assuming is a return line, for it went toward the back of the tractor. However I cannot find a connection where the line connects, if anyone knows would appreciate a reply. Thanks!
Roy Z
   / Need to Know #2
I'm not familiar with JD tractors built for European sales but look for a tube barb(parts key 12) on the RH side of trans shifter cover.
   / Need to Know
Tx Jim
I thought this line went to the transmission, but I tried to trace it down and couldn't find it. I purchase the tractor a few years ago at an auction, has needed a lot of minor fixes, but is a good tractor. There was so much dirt, grease and oil on top of the transmission cover, I looked for this connection about a week ago, cleaning up as much as I could. But I just went out with the diagram you sent me and cleaned up a little more dirt and grease, and low and behold there was the connection. Thanks a lot for you time and info, you saved me a few bucks.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
2018 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-250...
