Crocus
- Joined
- Mar 22, 2010
- Messages
- 12
- Tractor
- Kubota B26 TLB
I purchased a used "Kubota" B/L2563 snowblower to use on the 3pt hitch on my Kubota B26TLB (540 PTO). I tried it only once with deep wet snow and the chute jammed with hard packed snow before I moved little more than a foot. After examining the parts diagrams for it and reading any relevant posts it looks like it was designed for a two speed PTO as on a Kubota L2250 to be run at 1000RPM. That blower can be front-mounted with different frame etc but the drive shaft runs straight to the impeller/auger for both types of mounting.
I can't easily increase the impeller diameter and modify the auger gear ration so I wonder if there is a gearbox somewhere in the world that could be bolted/welded at the drive input on the blower to double the RPM?
I also wonder if I welded on more blades onto the impeller or enlarged each blade as much as possible, would that work? The auger would still be turning too slow but it could produce a usable attachment. Otherwise it is a $1000 boat anchor.
Comments please. I already know I was a "dumb ***" for not researching more before buying.
