Need to find a motor- HELP
   / Need to find a motor- HELP #1
Tejas
Bronze Member
Hondo, Texas
NHL185, Kubota B7100
So, I am building a skid-steer mounted rotary cutter for a neighbors Bobcat 763...Appears to have 15gpm / 3000 PSI. I have done all the calculations, with the help of some of you (thank you)...my plans were to use the 6.15CU 6 spline/PTO hydraulic motor from Surplus Center...they are out till FEBRUARY!!!! Insane. Anyhow, I have tried searching the net and haven't found anyone else selling one. I'm reaching out to TBN for some networking help!
Thanks guys!!!
-here is the info from Surplus Centers website...if it helps
ITEM NUMBER: 9-7368-100
6.15 CU IN PTO DRIVE MOTOR
Anyone know where I could find something comparable? Between 5.5-7cubic inches?
Morning bump
   / Need to find a motor- HELP #6
Possibly try an Eaton Charlynn, or Parker distributor. Eaton Charlynn was one of the original manufacturers of the geroler motor.
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2025 CFG Industrial STSD10 No-Till Seed Drill Skid Steer Attachment (A49462)
2025 CFG...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
2017 Ram 4500 Bucket Truck (A52128)
2017 Ram 4500...
