need to drop JD X534 Tranny Pan
   / need to drop JD X534 Tranny Pan #1
tobyzellers
Damascus, MD
John Deere X534
I dropped a 3" by 3/8" metal pin accidentally into the transmission of my 1-year old John Deere X534 while checking the level. :mad:
Now I'm faced with dropping the pan to retrieve the piece. How hard is this to do? I obviously have to drain the oil from both front and back, and most likely replace the gasket and torque the bolts that hold on the pan. Can I just remove the bolts holding the pan up, drop it 3 inches and remove the dropped pin from the sump?
Any advice on this forum? Should I just take it to my dealer?
Toby Z
Damascus, MD
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
MCELROY 500 SERIES 3 TRACKED FUSION MACHINE (A50854)
MCELROY 500 SERIES...
1275 (A50490)
1275 (A50490)
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
