Need tips for new tractors
/ Need tips for new tractors #1
JayinNH
Raymond ,New Hampshire
L3010HST (Jezebel)
Any little tricks for maximizing the performance of a new tractor that the dealership doesn't include or tell you about.I have heard about filling the tires. It what areas does that help. Some of the land that I own is swampy. Is that a wise move to fill the tires? Is there anything to do to maximize the performance of the engine that is inexpensive? Any little tips would be great.
/ Need tips for new tractors #3
JayinNH,
I'd read the section here on tractor safety and do everything slow to start with. You can get in a lot of trouble quicker than you can bat an eye if you are not very careful. I'm not trying to scare you, just relating my experience from reading this board. I'm a new tractor owner too, and I think the people here have saved me from making some of the more common mistakes that can turn out to be fatal. Performance is not usually much of an issue unless you are an order of magnitude off in what you ask a given machine to do.
Thanks for the advice. This site is a great reference for someone who doesn't have much experience with tractors. This will be my first farm/commercial tractor and I intend to take it slow.I appreciate all the good tips, thanks.
/ Need tips for new tractors #5
Hi Jay,
I second Pete's observation.
It's a little presumptuous of me to speak up on this topic, since I am completely new to tractors myself, ...but I've been studying hard at TBN University for the last year-and-a-half or so. /w3tcompact/icons/wink.gif
Based on what I think I've learned here, I'd bet that the single thing that would most improve your tractor's performance would be to train the operator to a high level-of-competence.
By comparison, any "hot-rodding" tips would be wasted effort, ...if you can't get the most out of what you've got, how will getting "more" help?
/w3tcompact/icons/blush.gif
Using the rig will let you know about any areas which could stand a little improvement, THEN you can decide what to put (more of)your time and
money into.
Good luck, and happy tractorin'!
/w3tcompact/icons/smile.gif Larry
/ Need tips for new tractors #6
Larry,
Does this mean I can no longer blame lousy work on my lousy Kubota, NH, JD?
You're saying there could be another possibliity?
Lousy me?
DRAT! /w3tcompact/icons/frown.gif
del/w3tcompact/icons/smile.gif
/ Need tips for new tractors #7
Jay,
I am a relative newbie in the tractor seat, but the best performance upgrade goes between the ears of the operator! Here are some web locations to visit to learn more about safe operations. There's a reason farming is one of the most dangerous occupations, it's the equipment.
Read, learn, interact, but above all else think! Oops, sorry, dern soap box jumped under my feet /w3tcompact/icons/blush.gif
http:// [url]http://www.cdc.gov/niosh/nasd/menus/toptrac.html [/url]
http:// [url]http://www.equiptrain.com/tlbbook.htm [/url]
Have some fun and don't get hurt!
John Bud
/ Need tips for new tractors #8
Jay, Kubota has a little book on tractor safety that is available for free. To be able to tell someone all there is to know about tractor operation on your parcel can only be done by visiting it. The operator is the main key as to what can be done with a piece of equipment. I've found watched machinery being run a lot of different ways and with varied results. On the calcium in the swamp, if there is a bottom to it the extra weight will get you there faster if there isn't it will still get you there faster. For the swamp the wider the tire the better to float across with less ground disturbance if you don't want ruts to go across the next time.
/ Need tips for new tractors #9
Jay: Take your time and get to know your vehicle is one of the better safety items. As for extras and swamp stuff, I'd get a good set of chains . Also, be careful of those soft spots - you can drop a tire in a squishy real easy... You may also want to practice scoop-walking; put your bucket face down and raise the front end a little, put ractor into reverse (SLOWLY) and rotate the bucket at the same time. This gets your front end out of the muck and snow in a straight line (front wheels slightly elevated so no steering).
Now putting on my NH Conservation Commissioner hat - whaddya doin in a swamp with a machine /w3tcompact/icons/shocked.gif (get your permits - trust me - its much cheaper that way)/w3tcompact/icons/wink.gif.
Andy in NH
Andy,
I see what you mean by chains. You doctored your baby up nice.I know a somewhat cheap investment like chains will pay for itself right away for me. The snow is melting and the soup season has started. Thanks for the advice. Do you know of a reasonable place to purchase chains?
/ Need tips for new tractors #11
I bought my chains from B-B Chain, which is downstairs in Chappel Tractor. They also run two trucks around the area and will come to you I think.
The double loop chains for my 3710 Ags (12.4-24)were $305. A bit more then tirechains.com but they fit perfectly and there was absolutely no hassle. Unless there is a significant price difference I usually support my local dealers (that way they are more likely to have what I need when I need it).
I had been looking at the type that has short loops connecting the cross links but the chain guy pointed out that they have a tendency to slip on ice. I don't think these have slipped yet!
Andy in NH
Andy,
Thanks for the tips. I'll be sure to look into some chains for the girl when she arrives. Maybe Mears could throw some in with the tractor (wishful thinking). Do the chains hookup to the tires easily? Do you keep them on all year?
Jay
/ Need tips for new tractors #13
Hook-ups aren't too bad. I will probably take the chains off once the ground firms up unless I am going to be in the woods alot. They are a bit bumpy when you are trying to go anywhere.
Andy in NH
/ Need tips for new tractors #14
Nice rig you've got there Andy. How do you like the winch??? I've got a norse 400 and it's been tough as nails./w3tcompact/icons/smile.gif
Gordon
/ Need tips for new tractors #15
Winch was great for the little time I got on it (before all the snow piled up and I couldn't play in the woods anymore /w3tcompact/icons/frown.gif). Soon as mud season subsides I expect to spend quite a bit of time with it.
Andy in NH
2019 Ford F-250 Knapheide Service Truck with Liftgate (A61568)
2019 Ford F-250...
6 Band Wooden Barrel (A61569)
6 Band Wooden...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pallet of Chain Slings (A61166)
Pallet of Chain...
