Need suggestions on top cylinder
   / Need suggestions on top cylinder #1
Rick_Taylor
Decatur, TX
Power Trac PT-425, Kubota L4330HSTC Kubota RTV
I need some suggestions. I just bought a new Kubota 4330HSTC with Kubota supplied TnT. When I reinstalled my Pat's EZ change onto the Kubota it became apparant that the top cylinder is too short to allow the box blade to tip over enough to allow smoothing with the rear blade. The dealer is trying but says he can't find a cylinder that is the ~3" longer that the Pat's sets back the lower connections. He wants to weld an extention onto the top end of the cylinder. Can you guys tell me what is a good working length and stroke for a top cylinder that will be used with a Pat's EZ change?
   / Need suggestions on top cylinder #2
Rick,
Both my original manual top link and Kubota's hydraulic replacement opened up to around 31 to 33 inches, can't remember exactly. (L4330) Seemed like more than I would ever need although I don't have the hitch like yours. Maybe they used the wrong one on yours?
Although you didn't ask, you might check to see if those TNT cylinders leak down before you let the dealer attack it with a welder. Its really a pain on the side link if they leak. If they do leak down, I would use this opportunity to get a credit for Kubota's cylinders and then go buy a set from Integration Engineering with the piloted check valves. Also they have cylinders in various lengths so you may get a proper cylinder length without a patch job. I posted my experience with these two systems in two different posts that I will try to link here.
Kubota's TNT
Integration Engineeering's TNT
John
   / Need suggestions on top cylinder #3
The entire inventory of Integration Engineering cylinders and TNT kits are now sold by Carter & Carter Machinery (CCM) at very reasonable prices. Take a look before buying elsewhere.
CCM top links and TNT kits
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
