Need Sugestions for DC electric/hyd valve
   / Need Sugestions for DC electric/hyd valve #1
skidsteer.ca
Western Ontario
Bobcat 553, 773, S185, Nh LS 160
I have a skidsteer cement mixer that operates on up to 20 gpm flow to turn the mixer, I'd like to split a small portion of that flow off to control a 2" double acting cylinder with a 6" stroke to control a side discharge door. (presently run of a air cylinder that requires the air tank recharged every 15 or so cycles)
Should be power on for open or close and spring centered to hold the cylinder in a statonary position.
Surplus Center has some but the base plates ports are only #6 and would be to restrictive I think. (we use 1/2 " hose)
Does anyone else have a source for simular valve with larger ports?
Ken
7021 (A50322)
7021 (A50322)
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
