Need Subsoiler Info
   / Need Subsoiler Info #1
Newmicon
Murray River, PEI, Canada
Hey there,
I am going to start planting grapes, looking at 10ish acres.
One of the major attachments I am looking at for my tractor is a subsoiler. However I know little about the requirements on the tractor.
Typical information. How much HP does my tractor need for each length blade? How heavy/big does my tractr have to be? etc...
Are there any threads/guides out there explaining them? I did a quick search out there and couldn't find what I was looking for.
Thanks,
Mike
   / Need Subsoiler Info #2
Subsoilers pull hard. I have bogged down my 85 hp 7610 pulling a single shank about 16 inches deep in dry soil.
Depends on depth, type of soil, and moisture content.
Ironically, subsoiling does the most good when it's dry because the hardpan shatters, but that requires max hp and dry soil wears out the subsoiler point much faster. You can feel it jerking the tractor as it breaks the hardpan into clods.
I was looking in only getting a tractor that was 44 hp.
I'm assuming I'll have to upgrade the power a little bit (quite a bit)?
   / Need Subsoiler Info #4
Rent the required horsepower if you will never need the HP in the future.
   / Need Subsoiler Info #5
Yeah, what he said. It is really rare that you need to use a subsoiler. When you do you don't need it that often. Maybe only every few years. A subsoiler is not for plowing or cutting furrows, it's for breaking up hardpan. Think of a butter knife cutting through butter. Now, that's NOT what you want. Think of a butter knife pressed hard on a cookie shattering it into several pieces. Now THAT'S what you want. I would see about having someone come out and subsoil it once and only when needed. If you get that big of a tractor you MAY find that it's cumbersome for the other 99.9% of the tasks you need it for.
   / Need Subsoiler Info #6
Are you using the subsoiler to break the soil deeply in the rows where the vines will be planted, or between the rows, or both. Some of the growers around here use subsoilers to break the rows where the vines will go. Seems like grapes have a real deep root system. I don't know what they do in older vineyards. Anyway, subsoilers with a shank that curves forward sharply will pull easier than one with a straight shank. If you look at pictures of 5 to 7 shank V-plows you will see what I mean. I have a single footed subsoiler made from a V-plow point, and I pull it in very hard dry soil with a 33HP tractor, but it does pull very hard. Put your seat belt on while you use it. I will add that my tractor weighs about 5000 lbs., with a 158 CI motor, that weight and size helps a lot.
Both.
Of course for the ground prep but a lot of wineries seem to be going in between the rows every other year to promote downward growth of the roots.
How deep is your subsoiler for your 33HP tractor?
Do you have a model number?
I'd prefer not to rent since I plan on planting quite a bit, but if it is the only option. I was hoping I could do at least 'some' subsoiling with the Kubota L4400HST that I was planning on buying which is about the size that I will need for my everyday jobs.
   / Need Subsoiler Info #8
Soil type/soil conditions will dictate how much power and how deep and how fast you can pull a subsoiler. I've got a Fred Cain heavy duty single shank subsoiler that I can pull at 4 to 4-1/2MPH behind a 47 hp/5100 lb 2wd tractor without too much strain on the tractor, at 20" to 24" deep. (any deeper and you're likely to get into solid limestone around here) I've had it behind a 60 HP/7500 lb 2wd tractor and moved along at speeds above 5mph.
As was mentioned, subsoilers do their job better when soils are a bit on the dry side. (late fall is best) In wet conditions, you simply rip a single narrow groove. That "heals" back and in no time, you've wasted the effort. Dry ground shatters. Too dry requires huge amounts of power and wears the subsoiler.
Thanks for all the info.
My soil is a Sandy Loam.
For now I'll stick with my initial tractor size. Been looking online and should be able to find a used subsoiler with a single shank for a few hundred bucks.
I'll play around with that and rent later if need be.
   / Need Subsoiler Info #10
Where ya located? (probably not very close.... Not much sand/loam here in Central Kentucky ;)) I've got a good one I'm thinking about selling. At the very least, you could try it on for size. (Single shank Fred Cain brand, in like new condition)
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
