Need starter wiring color codes
   / Need starter wiring color codes #1
Dustin Sparks
Mahindra 5545
I'm trying to get the starter wired back up I didn't remove it just trying to fix it starter was rebuilt
Any info or input would be gratefully appreciated
   / Need starter wiring color codes #3
For give the ignorance, but how hard can it be? How many wires are you dealing with other than those that go on the main post with the battery positive cable. One small wire goes to the solenoid, (usually a spade terminal) all the rest will have ring terminals the same size as the cable end. What else do you have?
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
John Deere 750 Drill (A50514)
John Deere 750...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2024 John Deere 872GP Articulated Motor Grader (A52143)
2024 John Deere...
