need spec sheet for gcwr 1994 f-350
   / need spec sheet for gcwr 1994 f-350 #1
ALKY
bedford co. pa
tym 233hst
need a copy showing gcwr of 1994 f-350 4dr dually 4x2 460 auto.i'm titling this inPA and want this for future combination tags.Ford dealer says to old for there data base. Please help! thanks:eek:
   / need spec sheet for gcwr 1994 f-350 #2
Why do you need the GCWR from the factory?
Your rear axle should be a Dana 80 and your front axle should be a Dana 60...
What ever the weight rating on the axles will give you the legal limits of loading your vehicle...
You can tag up to 26K without a CDL...
Just don't overload your axles on the truck...
Just a guesstimate but the factory GCWR for your truck is probably in the 15K to 20K range...
Pa requires it to place it on the title.if u don't have combo tags u are limited to 10k.payin xtra fees don't help DOT goes by the numbers.after all it is PA!
   / need spec sheet for gcwr 1994 f-350 #5
If your Ford dealer does not have it...
And...
It is not on the internet...
And...
You can't get a copy anywhere...
How does anybody in Pa register anything that is old without the GCWR certificate???
it can be registered,just can't tow a trailer over 10k,without combination tags.ie more $$ 4 pa
   / need spec sheet for gcwr 1994 f-350 #7
Gotcha...
Here in NC you have to tag the trailer to be legal...
Set fee...
You pay for the truck tag based on the weight...
in pa,it's like that until 10k on trailer,above that u pay combo and trailer.ex. truck 10k,trailer 14k =24k tags for tk + trailer tag ugh!! PA is great!
   / need spec sheet for gcwr 1994 f-350 #9
i know a 2wd f350 is not going to have a dana 60 steer axle. its 2 wheel drive.....
i am 99% positive that a '94 f350 does not use a dana 80 rear axle. (my '97 f-super duty does, but it is 10-lug, disc braked, and can handle quite a bit more weight than an f350)
   / need spec sheet for gcwr 1994 f-350 #10
Rear axle should be the 10.25" Sterling.
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
