glinke
I have a '62 40403 - heavy duty industrial. It's a 4 cylinder gas. It has been converted to 12-volt negative ground with a three-wire alternator. It has a 4-terminal solenoid. Currently the positive from the battery goes to the front terminal as well as a wire going to a pushbutton switch (broken) on the dash. Another wire comes from the other terminal of the switch to the "s" terminal of the solenoid. The "i" terminal is empty. The back terminal has a cable going to the starter. Jumping from the front terminal to the "s" terminal spins the starter.
Since the switch is broken, I want to go back to the original starter button down by the shifter. I have a new starter button installed. The transmission is in neutral. If I hook either of the wires from the old switch to the new one and press the new switch, nothing happens. The position of the ignition switch - also not original - does not make any difference.
I want it to work like the original - ignition switch on, transmission in neutral, press starter button, starter turns.
Any help would be greatly appreciated!
Oh, If I want to replace the wiring harness, do I need a 6-volt one - what it was or a 12-volt one?
I have worked on vehicle electrics before, but none as chopped up as this one.:confused2:
Gayle
Gayle
