Backhoe Need some pics of the 3710 BH rear couplers
   / Need some pics of the 3710 BH rear couplers #1
alia176
Tijeras, NM
Mahindra 3316HST
Can I see some pics of the holder/bracket that holds the BH couplers please? I'm thinking of adding this to the rear of my 3316 with the 3720B backhoe. Currently, this coupler connection sits behind the engine, under the tractor which I find to be less a than ideal location. I should be able to move the connections to the rear and come up with a better solution.
Those of you not familiar with the 3720B unit, the subframe is part of the BH and the whole thing needs to be dropped when you detach the BH from the tractor.
Thanks.
   / Need some pics of the 3710 BH rear couplers #2
Thanks.
alia, I have the 3710 which I use on my 2615. The 2615 also connects under the tractor not in the rear. Had I had the foresight, I would have had rear remote couplers added at purchase time.
Here is an owner of a 3316 who has already gone through the process: http://www.tractorbynet.com/forums/hydraulics/283227-adding-rear-hyd-mahindra-3316-a.html
Ok, so the 3710 & 3720 both have subframes that are attached to the BH with the coupler connection under the tractor, near the engine.
Anyone else have a different BH with the coupler connections in the rear? I'd love to see some pics! Maybe I'll go the parts catalog for a 3016/3616 and see what they have. I should be able to use their design and make it work on my tractor.
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
1996 CHEVROLET CAPRICE SEDAN (A52576)
1996 CHEVROLET...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
