Box Scraper Need Some Information
   / Need Some Information #1
not2clever
NE Nevada
Mahindra 3016 Shuttle
I am in the process of purchasing a Mahindra 3016 (picking it up next weekend) and I know that I should get a 60" box scraper for it. Well, we measured the widest point on the tires that are mounted on the Mahindraheand and it is 61.5 inches. I know it is recommended I use a 60" box scraper, but would it be ok to go with a 65" so it is slightly wider than the width of the tractor? I am new to this and don't want to screw anything up.
Thanks,
Dave
   / Need Some Information #2
hi, Dave . before you buy the 66" box blade check to see if the tire and wheel assemble can be reversed making your trac narrower. I have a 2 pc. wheel and can be reversed to make the trac wider or narrower. If not you can go with the wider box blade, you just dont need to go wider than the 66".
I don't have a mahindra, and don't know the wheel set up on them.
Hope this helps.
P.S. you may want to repost this thread in the Mahindra, discution board.
all the best
David
New Idea Manure Spreader (A50515)
New Idea Manure...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
