Need some info on JD Cab Radio ideas....
   / Need some info on JD Cab Radio ideas.... #1
nmu98
Veteran Member
JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
I put in the order for my cab tractor over a week ago and I have 2 weeks to go til I can pick it up. I am looking at radios to put in the cab. Wanted a pioneer but I don't know what I will decide with. I want a USB connection... And suggestions welcome.
The Question: Do I need to buy an antenna kit or does one come with the JD radio mount kit? Best Buy had a nice T antenna that you could stick on a window or plastic for 16.99.
Also, should I buy upgraded speakers or ar the ones that come with the radio mount kit OK. Most other 4x6 speakers are about 30-40 dollars. I also saw a small set of tweaters that would be easy to mount.. Worth it?
Thanks for the help.:D
   / Need some info on JD Cab Radio ideas.... #2
When you get the Radio Mount Kit, it comes with the antenna and everything you need (speaker, etc)...Personaly I think my stereo sounds great...I wanted an Alpine at first but I ended up getting a Kenwood on Clearance for 99.00 (AM/FM/CD/MP3/WMA/iPod Ready)....really nice unit... went back a week later to get one for my dads 'bota and I got him a Kenwood with USB input for 69.00 on clearance...
For my use the Kenwood Headunit and Factory Mount Kit are more then enough...
   / Need some info on JD Cab Radio ideas.... #3
For some reason, I am looking to install my portable SAT RADIO in mine. I guess i want the challenge. I have trees but only the house willl block the signal completely
   / Need some info on JD Cab Radio ideas.... #4
I put a Kenwood KDC-MP438U in my 5425. It has a USB plug and an auxilary input on the front. The tractor came with the antenna, wiring harness, and speakers. In my opinion, the factory speakers have very, very poor sound quality. However, when running at full PTO rpm, it doesn't really matter. :D
The only issue I've had with my install is finding a constant 12 volt power source. Everytime I turn off the tractor, I lose any programming in my radio. Hasn't bothered me enough to break out the multitmeter though. ;)
Wow, 2 kenwoods... i was expecting more people to use Poineer... no clue why....:confused:
I am stuck between the kenwood and pioneer. both have the multi push volume know that also controls menues. Not what I think is best for a tractor... but...
Since speakers are resonable. i guess i should change them out right away... Saves tearing the roof off over 40 bucks......:p
   / Need some info on JD Cab Radio ideas.... #6
I went with with Kenwood because it was the cheapest radio with a USB and aux input. :D Came with a remote too!
   / Need some info on JD Cab Radio ideas.... #7
Did you get the factory harness? If so, that doesnt sound right...Mine plugged right in with no splicing of the factory harness at all (used the Adaptor Plug to adapt from Deere Harness to Kenwood) and everything works fine..its got power all the time, etc..
It has power all the time (you have to shut it off all the time) or it has power to save the memory (radio shuts off with the tractor key)?:confused:
   / Need some info on JD Cab Radio ideas.... #9
I used the VW wiring harness. Everything worked great, 'cept a constant 12 V source.
   / Need some info on JD Cab Radio ideas.... #10
It has a constant feed with power all the time and a remote wire which turns the head unit on/off with the ignition key. Turn my ken ON and the unit fires up, shut the tractor down and she turns off...just like your car or truck...
See Page 16 of this PDF:
http://inform3.kenwoodusa.com/manuals/kdcmp238.pdf
In my case (Kenwood)... Red Wire is to the Ignition (Switched Power), Yellow goes to BATT (Constant Power) those 2 wires are what control what your describing...often times to save time or wiring hassle, people will & can put yellow & red together...which makes the head unit operate as you describe...
SKID STEER QUICK ATTACH HYD COLD PLANER (A54756)
SKID STEER QUICK...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
UNUSED FUTURE QUICK ATTACH PALLET FORKS (A54757)
UNUSED FUTURE...
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
