lzicc
Platinum Member
I have a storm drain at the end of my driveway that leads out to the storm drain out at the road. I would say from the drain on my driveway to the one at the road, the distance is about 30'. The drain of what I can see is half full of clay type mud. I reached in as far as I could to clean out what I can which is only a few feet. The drain pipe is about 12" wide. I tried to push a 1" flexible plastic pipe through to get to the other end, but it stopped after about 20". I did put a pressure washer in the try to flush the dirt through, but again, that only reaches in so far. With the angle that the pipe is from the surface of the driveway, I have no way of sticking anything rigid in there. If I could have got the plastic pipe to come out the other end, I was going to feed a steel cable back through, tie a concrete block to one end and pull it through using my tractor, but I don't think I can get anything the whole way through. I'm not sure what I am hitting when I go 20', maybe an elbow or something, but I did try. Any ideas on how to get this cleaned out?
