Oil & Fuel Need some help with satoh 650g
   / Need some help with satoh 650g #1
beeru67
Hey guys i have a satoh 650 g bison tractor and need some help on the oil i should use. I did some research but couldn't find much so heres what i got.
For my engine im going to use a 10/30, 10/40 or 15/40 oil, which one should i use and which is the best?
For the transmission im gonna use a 80w gear oil and for the hydraulic im going to use JD type 303 or international hytran. Never heard of these last 2 so can someone tell me if these are the right ones I should be using. And another thing under the tractors seat is a hole to put in the oil and the cap is white but there's a another hole right above the gear shift and that cap is red? So im guessing hydraulic goes in white and the other in the red? Thanks :)
   / Need some help with satoh 650g #2
I use Universal Tractor Fluid for hydraulics . You can get it at any auto parts store ... I spent most of the winter tearing apart my hydraulics on my 650g , so I know UTF works fine .
You should go on Ebay and get yourself a service manual .
Alright thanks alot, ill need to check my local lordco if they carry it.
   / Need some help with satoh 650g #4
Valley Power
try this link you may find some useful info.
2025 AGT LRT23 (A50123)
2025 AGT LRT23...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2017 John Deere 30G Mini Excavator (A51691)
2017 John Deere...
Pallet of  (4) Lincoln A.C. Motor TEFC (A53117)
Pallet of (4)...
American G-Model Pump Jack (A53473)
American G-Model...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
