Need some help with MF 285
   / Need some help with MF 285 #1
boice1971
Casar, NC
MF 285
Hi everyone, this is actually my first post and I'm hoping to find a little advice.
I have a 1975 Massey 285 and I'm in the middle of replacing the center steering shaft (part #532219M92) and bushings (part #194624M1).
I first "dry fit" the new shaft to make sure everything looked right; and it did. I tapped in the new bushings and went to install the shaft but it absolutely will not fit through the bushings. I even went through the trouble of putting an angle finder on the tractor and shaft to make sure everything is lined up correctly and then put a bottle jack under the shaft and it picked up the whole front of the tractor instead of pressing the shaft in. I've checked and double checked that I ordered and received the correct shaft and bushings and everything seems correct.
Any suggestions on what I can do?
Swict 84" Bucket (A50121)
Swict 84" Bucket...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
