IIIBradIII
Bronze Member
I have a 135 diesel that I need to order some parts for and want to make sure I order the correct ones. The numbers below are all on the left side of the engine and I'm putting them in order from top to bottom as they are found on the engine itself:
2313164 - stamped directly into the steel, located directly below the exhaust manifold
37111450 (the first 1 looks like a 1 but the next two 1's have either been knocked down or something - barely recognizable) - directly behind the injector pump and hard to see behind the fuel lines
5 - near the manuf logo (at least I think that's what it is - it has a couple coats of paint over it) is just a "5" all by itself
415 - also near the manuf logo (see above disclaimer) but this number is turned at an angle - probably something like 110 degrees counter-clockwise
GKN1842 - closest to the bottom, near the sump/oil pan, behind the steering arms - seems to be the only one located on some sort of placard (rather than being a part of the casting [raised numbers]) like some of the others
0941076 - this one is not so much located on the "side" of the tractor as it is on the "front" of an area jutting out where the engine bolts onto the rest of the tractor
I'd appreciate any insight. Thanks.
