need some help,answers on backhoes
   / need some help,answers on backhoes #1
Nat
Platinum Member
Central NC
I posted this on another forum and I hoped ya'll could help.
I'm going to build a new house and want a backhoe around during construction. I bought a 7 ac tract and it will require a good bit of grading, ditches, water lines, footings, and will need a loader to put plywood/ stuff up to roof level. I have looked at several,ie ford 555A-case 580C-JD310A- Ford 3400-Ford 4500. I have also found a big Dyna-hoe. The Case,Fords,JD all were fairly rough, The 555 and the 310 ran and worked good,tires good.
The Dyna-Hoe is in much better condition, paint,tires, overall apperance. I will be selling whichever machine, after the house is complete.
My question is how much money difference would you folks think is reasonable, since the Dyna-Hoe is a " offbrand"?
I have bought and sold several hoes/loaders/dozers/skidsteers ect. over the years, but have never owned a Dyna-Hoe, so don't know the price difference. I do know the if you compared the ford 555 to a ford 555 that is in the condition of the Dyna-Hoe, it would be worth 1500-2000 more than the rougher one. I also know a comparable 555 would be worth more than a Dyna-Hoe in the same condition. If I were going to keep it it woildn't make any difference, sense the old Dyna-Hoe are tough, slow machines but knowing I want to sell after the job is done how much will being "offbrand" hurt the sale of the Dyna-Hoe? Anyone have any ideas, or opinions?
Thanks, Nat
   / need some help,answers on backhoes #2
Your profile doesn't say where you are, but Dynahoes were pretty popular up in the Northeast. Typically, they are very strong and a little slow compared to the newer tractors. Originally built by Bucyrus Erie... They pretty much use off the shelf components so parts shouldn't be a major issue. The older ones were detroit powered, later models got JD engines. The JD powered machines typically bring a higher price. You might check Equipment trader for machines near your area for price. There are usually several for sale. HTH
Scott, I'm in central NC. Very few Dynahoes around,mostly Ford, Case, JD, beginning to see some Terex.
This is a 180,I think.2 WD with a detroit. It weighs 5000 lbs more than the 555, so I'm sure it will do the job, it seems to be in very good shape. All I'll do with it is clear a few thickets, water lines, footings, ect. Biggest concern is how hard will it be to resale when I finish the house, I never tried to sell a Dynahoe
   / need some help,answers on backhoes #4
The 180 is the "little" one... The dynahoe's were built to take up the space between regular hoes and excavators.
I'd imagine it will take some longer to sell with less value than a more mainstream machine. Detroit ain't doin it any favors either... Decent engines but really loud...
I looked at it today, it's a 160. Man that thing is heavy, and slow. Did I mention slow? It ran and worked good and is in good overall shape. Only problem, no brakes, 1 wheel cyl leaks, and no individual wheel brakes. The seller has a lot of southern yellow pine and was going to try to push 1 over that was 16" at the stump. It broke clean off 2'high and the hoe didn't even grunt. I dug the stump out and it would lift the front end off the ground just crowding the bucket in. Did I mention slow? the steering is slow and makes it seem even bulkier when I filled the stump hole. I felt like I was on a locomotive, it seemed to be 2 times the size of the 555, and moving dirt I expect that the 555 will move more in an hour, but not in a bucketfull. If that is the little one the big ones must be something. I think I'll go with the 555, unless something different comes up in the next day or so
   / need some help,answers on backhoes #6
Just looked up Dynahoe in my earthmover encyclopedia...
Think that one was tough? Try a 200-4. (4 means 4x4, they were equal sized tires and 4wheel steer too)
The 200-4 had 160hp and weighed 38,490 lbs! /forums/images/graemlins/cool.gif
You look at this one?
Here's a 200-4
This must be a later model after Northwest bought dynahoe in the 80's. 490-4
Probably more than you wanted to know about Dynahoe.... What can I say? I'm a junkie...
   / need some help,answers on backhoes #7
What a beast that 490 looks like. Thanks for the link. The biggest problem we've encountered with Detroit's engines is the starter current draw.
Yep, Scott, that is the one I looked at, He's about35 miles from me, seems like a nice guy, I sort of hate not to buy from him, but that thing is to big and slow. I bought the 555, will be delivered on friday. I'm going to paint it and decal it up before I take it to the land.
   / need some help,answers on backhoes #10
There is an old 1975 Dynahoe 200-4 on Machinery Trader. It has been listed there for a few years, at least. When it was first listed, it was for $11k. Since they figured it wasn't selling, they must have thought to clean it up and paint it and charge $4k more. /forums/images/graemlins/shocked.gif
Looks like a tank, though. /forums/images/graemlins/cool.gif
1975 Dynahoe 200-4
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2014 Ford E-350 16ft Box Truck (A51692)
2014 Ford E-350...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
City of Lakeland (A51691)
City of Lakeland...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53473)
UNVERFERTH 330 -...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
