Need some expert advice!
   / Need some expert advice! #1
Dawnn
Belmont, New York
Ford 7600
Good morning, my name is Dawn and I own a hesston 530 round baler and a ford 7600. My question is how do I load the twine into it. My husband recently passed and while I can drive,mow and bale, I don't know how to load the baler. Any and all help would be greatly appreciated. Thanks in advance.
   / Need some expert advice! #2
I suggest you use the same type of twine as used before, so no tension adjustments are needed.
The box holds 2 rolls of twine.
Leave the plastic covering on the twine roll.
Pull the starter end from the inside of the roll and put it up through the hole in the lid.
Feed the twine through the twine tension bracket on the lid.
Feed the twine down through the guide at the front of the twine arm.
Continue feeding through the arm and the tensioning spring plates inside the twine arm channel.
Pull the twine out the lower end of the arm and have 12-15" hanging free beyond.
Put the second twine ball next to the first, leaving the plastic on. Pull the starter string end from the center
and tie it to the outside end of the first ball with a square not. Make the not small and clip the ends.
When the first roll runs out it will continue to pull the second roll through.
Ron
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
Kohler 100P2288 (A47384)
Kohler 100P2288...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
