Buying Advice Need some buying advice!!
   / Need some buying advice!! #1
lithia,fl
John Deere RX75
I am thinking of buying a ford 1100 diesel tractor from a neighbor. He started the tractor and it blew a plume of white smoke out the exhaust pipe. He is still thinking of a price. What kind of things should I look for next time I take a look at it? Is the white smoke at start up a big issue?
   / Need some buying advice!! #2
The white smoke could be from setting too long, bad fuel, lot of hours, etc. If if clears up and runs strong, it's probably fine.
   / Need some buying advice!! #3
White smoke is generally associated with moisture. If it smells sweet it is antifreeze which might indicate a headgasket issue. Being that you are in Fl there may or may not be antifreeze in the cooling system, although there should be.
   / Need some buying advice!! #4
It's not unusual to get smoke during start up...as long as it abates in 5-10 seconds, I would not worry about it.
I'm not a Ford/New Holland guy, so I'll leave specifics to those experts.
However, the 1100 doesn't have much power...about 11 or 12 PTO HP. Is that going to be enough for your requirements?
Thanks for the advice roy, im hoping that the tractor will be enough horsepower because all i will be using is a pto mower. The smoke only really happens while cranking the engine, then it clears up.
John Deere M Tractor (NOT RUNNING) (A50774)
John Deere M...
Wood Fence Posts (A50121)
Wood Fence Posts...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
(2) Final Drives (1) Front Axle (A50121)
(2) Final Drives...
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
