Buying Advice Need some advice on the purchase of a Case 860 turbo
   / Need some advice on the purchase of a Case 860 turbo #1
hcforde
Bronze Member
austin, tx
none yet
I am totally new to heavy machinery. I am considering buying a Case 860 Turbo trencher. The one I am looking at has a leak at the joints in couple of the hoses for the backhoe, and one of the hydraulic cylinders that operates the plow has a leak.
It has about 2700 hours on it and thing I should look for?
It seems to start easy enough and the backhoe works. Is there anything that commonly goes bad on these that is not obvious for a novice to spot?
How would I spot issues with the Turbo? If there is a problem with the turbo part, would it run regardless? what would be the effects just less power or could damage be inflicted?
What should I ask to be demonstrated?
I want to buy this because I will be needing to trench water and electric lines on 37 acres(or maybe 87 acres as another 50 acres is available). The primary acreage(25 & 12 acre parcels) is in 2 parcels about 1000 ft from each other with a right of way between the 2 parcels. I also will be trenching for passive cooling(laying air and water tubing) of greenhouses on the property. It won't be used day in and day but as the need arises. But I just want something that will be time efficient and overall cost efficient for the (over time) extended projects I have in mind.
   / Need some advice on the purchase of a Case 860 turbo #2
Can you send me a couple pictures, I was in the underground business, and did all my own repairs. I might be able to help a little with photos, although it's not like being there.
44511 (A51692)
44511 (A51692)
2019 CHEVROLET SILVERADO 1500 (A52472)
2019 CHEVROLET...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
