kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,928
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
My parents have a Craftsman mower that痴 about 3yrs old, and I bet the motor doesn稚 have 120 hrs on it. It has a 22hp Kohler Courage series engine, which is a single piston engine. This past summer was EXTREMELY wet for SC, which means that the grass grew like crazy, faster than we could keep up with it because I could only get up there on weekends to do it. My dad is 82 and mom doesn稚 like him to run the mower when I知 not there, so it only got cut once a week. Well, by the time I would get up there on Saturday, the grass would be a foot tall, and usually in the mornings it痴 still wet from the dewfall. That meant that every time we cut it, the deck would just clog up to the point that I had to rig a bungee cord to hold up the discharge chute just so it could spit out the huge clumps of wet grass. Still, if you weren稚 careful, it would clog up and choke the mower down. That痴 just how bad it was almost the whole summer!!
So all that background info leads to the issue. When we were cutting the grass like that, it was lugging the engine a lot, which isn稚 good for it. I noticed the last time I used it a couple weeks ago, after shutting the motor off, and while it was spinning down, it had a terrible knock to it!! Paying closer attention, you can hear it when it痴 running, but it痴 not as noticeable, but probably because of the exhaust and blade noise.
This leads me to the question?. should I go ahead and take it to a repair shop this winter and let them tear into it and see what exactly has worn?? I suspect it痴 the bearing on the connecting rod and maybe the wrist pin too. That one big piston has a lot of mass, and coupled with the down pressure from the firing stroke, it was probably beating the heck of that bearing. It doesn稚 smoke or use any oil now, but I know if I keep running it like this, eventually something will come through the side of the block.
Has anyone dealt with a similar situation before? If so, what was the damage to the engine? Thanks for your comments.
