Need Shibaura Parts
   / Need Shibaura Parts #1
eldridge
I have a Shibaura SD3000D 4-wheel drive. Need (2) right front end parts that connect to the "differential shaft" (axel). The parts are called (1.) joint and (2.) final pinion. Anyone got any advice please?
   / Need Shibaura Parts #2
Any luck checking with a Ford dealer? I have a used tractor book, but the only Shibauras listed are Fords..........chim
Thanks for the reply. I did check with one Ford dealer and he said the parts are not the same. For some reason though I think he was just brushing me off. I plan on checking with other Ford dealers just to be sure.
   / Need Shibaura Parts #4
I think if there is a ford or new holland model that crosses with yours you will find most of the internal parts are the same the external areas are where the major difference are found.
   / Need Shibaura Parts #5
Check with Buck at efcconstruction.com
He's a shibaura wiz
may have a good idea for parts as well.
Nick
   / Need Shibaura Parts #6
Check this place. They can probably get them if available. I think this is where Buck at EFC gets his parts.
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
Smoke Daddy Portable Grill (A50515)
Smoke Daddy...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
(INOP) JOHN DEERE 5205 TRACTOR (A51243)
(INOP) JOHN DEERE...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
