Need rear remotes for MF 1532
   / Need rear remotes for MF 1532 #1
Millhaven, Ontario, Canada
Massey Ferguson 1532, Bolens G174
Hi everyone!
i want to know how MF plumbs up the rear remotes? My tractor will not have them and I want to install them fairly quickly so I can add a hydraulic top and side link. Can somebody provide a picture of the valves mounted under the fender and where the pressure and return line connect? I took a look at a larger tractor on the lot and the rear remotes were plumbed directly back to the hydraulic pump, unfortunately, the 1532 only has two ports from the pump, one for power steering and the other for the hydraulics. I imagine I will just have to "T" into the pressure and return line and run that up to the valves but maybe there is some other "trick"?
   / Need rear remotes for MF 1532 #2
I don't have a diagram for the 1500 series but I do know that you can't "T" into the pressure line. The hydraulics is open center and everything has to be in series.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
Toro Mower (A50324)
Toro Mower (A50324)
20" Sea Container (A47384)
20" Sea Container...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
