Need power@beyond for L295DT
   / Need power@beyond for L295DT #1
derrickvickery
Need to install front end loader. I was told I need A power and beyond valve
   / Need power@beyond for L295DT #2
</font><font color="blue" class="small">( Need to install front end loader. I was told I need A power and beyond valve )</font>
And your question is?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
What you want to buy is an open center 2-spool valve with power beyond. This will give you 7 hose connections, 4 for the work ports to the loader cylinders and 3 for the flow (inlet, tank, and power beyond). You will also probably need a hydraulic block connector to connect into your existing hydraulic circuit. Your tractor's parts or owners manual should be able to help here.
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
