need plow for gc2300
   / need plow for gc2300 #1
dahliagrower
just bought a new gc2300 with a massey ferguson 1351 tiller the tractor and tiller are great but i need a plow and hiller that will fit the tractor the dealer i bought the tractor from has been unable to find either one , does any one know if there are any that will fit the tractor the dealer does not seam to know ,the ones he has ordered have been for a standard size tractor and will not fit the low profile on the gc2300
   / need plow for gc2300 #2
Try Taylor Pittsburg. Make sure that they know its for a sub compact tractor and not a compact tractor in case lift hieght is an issue. 800-456-7929
   / need plow for gc2300 #3
FYI, sub compact tractors do not have any draft sensing, so if you are in heavy soils like clay you will have to raise and lower the plow with the hyd lever as you are driving as the load changes.
   / need plow for gc2300 #4
I had same problem getting attachments for my 2310. The dealer said the lo pro three point needs lo pro attachments. I could have gotten a deal on used yorkrake and graderblade. I didn't buy in case they don't fit. Lo pro yorkrake is around 600 dollars and wheel kit is extra. plowking
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
Hester 1206 10' V Disc (A50121)
Hester 1206 10' V...
Montreal ST225/75R15 Trailer Tires (A50322)
Montreal...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
