This is what I found (page 822)
<font color="red"> Control Panel
Removal:
1. Disconnect negative ( - ) battery cable.
2. Remove steering wheel. See "Steering Wheel" on
page 821.
3. Remove throttle control knob.
NOTE: On ePowrReverser machines, remove left cowl
and remove two bolts securing the reverser lever
bracket. Install in reverse order.
4. Remove screws securing control panel; lift off the panel.
5. Lift rear of panel and tilt panel forward. Reach under
panel and spread tilt steering lever arms away from
steering column steering wheel tilt mechanism.
6. Lift panel up and disconnect all wiring harness
connectors to control panel.
7. Remove control panel.
Installation:
Installation is the reverse of removal.
</font>
Do you need the "Steering Wheel" directions?
