Need Oil Filter for Husqvarna
   / Need Oil Filter for Husqvarna #1
stanj
Mt. Airy, MD
Toro
I have Husqvarna YTH24K8.
The part list shows oil filter 2505040
I need one in order to change the oil for the winter.. ?
I read that the K&N HP-1002 may work on my tractor but want to make sure and where to get a replacement
I checked Lowes, Home Depot, TSC..and didn't see one
Didn't check WalMart yet
thanks
   / Need Oil Filter for Husqvarna #2
That number is an old Kohler number. I would use the Kohler 5205002s , (1205001s is the shorty) but it is really the same size as the Briggs 492932s or 696854 if that is all you can find at the Depot.
   / Need Oil Filter for Husqvarna #5
Yes, should work. It's a bit more $ than some other compatible filters.
From looking at cross references, it appears that the oil filters for Briggs&Stratton, Kohler, and Kawasaki lawn mower engines are essentially the same, and interchangeable.
   / Need Oil Filter for Husqvarna #7
Yes, it will work fine...just a bit shorter. These engines are not high performance.
OK
..thanks....
   / Need Oil Filter for Husqvarna #9
My 26 horse Kohler Courage uses a Motorcraft 400s from Wallyworld. I have been using the 400s or its Puolater equivilent since the first oil change 900 and some odd hours ago.
Do some cross referencing and you can find a auto filter that will fit. A lot cheaper.
   / Need Oil Filter for Husqvarna #10
The spec should be about 7-9 pounds for the bypass release. An automotive type that will screw on will likely have a higher bypass pressure. Bypass is only important on cold starts or clogged filters.
PALLET OF 3 DEF TANKS (A45046)
PALLET OF 3 DEF...
Scag Turf Tiger 60in Zero Turn Mower (A42744)
Scag Turf Tiger...
1975 TEMPETE VAN TRAILER (A45046)
1975 TEMPETE VAN...
2016 Ford Explorer AWD SUV (A42744)
2016 Ford Explorer...
2003 Ford F-150 Pickup Truck (A42744)
2003 Ford F-150...
2012 CHEVROLET 3500HD PICKUP TRUCK (A43004)
2012 CHEVROLET...
