Need of hydraulic info - 3320
   / Need of hydraulic info - 3320 #1
sgtstew
I need to run a hydraulic implement on the rear 3-point.
What's the best way to access the front loader 4-function system - the only available connections that I know of?
I would expect that the loader operating lever would operate the rear implement if it were to be connected properly.
I can visualize putting the loader in a handy non-working low position and then making the disconnect to the hyd. 4 function access point.
question: will the loader status/position remain "as-is" when disconnected to hyd?
I would probably need a jumper to go from the 4-function point to the rear mounted hyd implement.
Suggestions??
   / Need of hydraulic info - 3320 #2
:welcome:
You can add a 3rd SCV.
You can add a diverter.
You can just use the curl side of the dual SCV for your FEL (keep the lift side attached)
Or remove the FEL, and use both sides of the dual SCV.
note: doubt the loader will remain in position if disconnected, for very long anyway. And reconnecting would be a pain. Best to remove the FEL, as it is a 2 min job.
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
2012 Porsche Panamera Hatchback AWD Sedan (A50324)
2012 Porsche...
Grundfos Centrifugal Pump (A50121)
Grundfos...
