need metric hydraulic cylinder for AC3 backhoe
   / need metric hydraulic cylinder for AC3 backhoe #1
texasjohn
Super Member
Central Texas, Jarrell
Kubota Grand L5030HSTC
Bought a 3ph backhoe off Craig's List, AC3 is the decal on it...absolutely no other markings.:confused: Fits a 50ish HP tractor.
Swing hydraulic cylinder is busted...cracked gland.
No sign of manufacturer or other markings on this cylinder or any other.:confused:
Took cylinder to local hydraulic shop... full service shop, good people, I trust them. They said that it is a METRIC cylinder and that they have no sources for metric parts....go back to the OEM...but I can't figure out who the OEM is.:(
I have no problem with purchasing a new cylinder...but it needs to be METRIC because the hose fittings are metric as are the pins holding it in place.:(
Have looked all over the net for metric hydraulic cylinder suppliers and/or parts. No luck.:(
Have called numerous hydraulic repair places in Austin and Houston...all say that their only idea is to have a new gland machined to order.:(
Surely I'm missing something simple here...
Photo of the cylinder would not be useful...it is a simple red cylinder with no markings on it... pins hold each end in place.
Does anybody know where METRIC hydraulic cylinders and/or repair parts can be obtained, I hope:)
   / need metric hydraulic cylinder for AC3 backhoe #2
How about getting a regular cylinder, get adapters to go from metric to whatever on the hydraulic hoses, and have new pins machined. The pins could get tricky; but I would think it's doable. Or get bushings made to fit the space between the metric pin sleeve and the inch system pin.
   / need metric hydraulic cylinder for AC3 backhoe #3
Possibly try one on the Chinese tractor dealers that advertise here on TBN, they sell backhoes made overseas and may be able to help you.
   / need metric hydraulic cylinder for AC3 backhoe #4
You do not say what repairs are needed. A simple rebuild of just o-rings would be easy so i assume it is something else?
Ken
   / need metric hydraulic cylinder for AC3 backhoe #5
Ken
Read his post again:
   / need metric hydraulic cylinder for AC3 backhoe #7
I'd head back to that full service hyd shop and have em build or modify an existing new cylinder to work.
   / need metric hydraulic cylinder for AC3 backhoe #8
Did you ask if they could make you one? Was the barrel damaged too? Most glands are pretty simple. Shop I work at used to do a lot of hydraulic cylinder work (mostly big coal mining equipment cylinders and a lot of it metric). Still do some but we no longer chrome plate and don't pursue that line of work much. We've made lots of glands, piston, rods, etc. Even complete cylinders from scratch. Having one made should be an option.
Kim
All parts apparently undamaged except for the clearly cracked gland and the threads on the gland. Threads on the cylinder appear to be OK....
If I'm unable to locate a source for parts/new cylinder, will see if new gland can be made...I had an over the phone estimate of $300 to make the gland (they didn't see the part, just ball parked it)....have seen many new cylinders for that amount, or less.... I'd rather a new cylinder or new part if available.
Idea to ask some TBN advertisers is a good one... will follow up.
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2007 FORD F-450 (A50854)
2007 FORD F-450...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
