Need LT160 wiring diagram
   / Need LT160 wiring diagram #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
Does anyone have a LT160 diagram they could email me or put up on the web? I have a no start condition but if I put 12V on the starter relay coil the engine will turn over. I checked the seat switch and it is functioning- continuity between the two middle contacts and also between the two outer contacts until you push in the button. There must be a safety switch on the brake pedal but I didn't have time to look for it yet.This is my mother's tractor and if I don't fix it quick she will try to use the old Simplicity 700! She's 80 and I'm afraid she will fall off of it when she lets out the "clutch", which is why we got her the JD hydro. Thanks.
   / Need LT160 wiring diagram #2
Can't help with a diagram, but there are probably at least three safety switches you will need to find and check:
1. Seat
2. PTO
3. Neutral
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
(2) Anchor Hedge Posts (A50515)
(2) Anchor Hedge...
