Need Landscape Rake Advice
   / Need Landscape Rake Advice #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I need to purchase a landscape rake for my JD4105 (40HP) for use raking-up debris and gravel road maintenance.
There are four offered by my dealer -- Frontier Models LR1072 & LR2072 (Standard Duty, 72 inches) vs Models LR1172 & LR2172 (Medium Duty, 72 inches).
Farm and Fleet has KingKutters YR-72, TYR-72 (Tubular), and YR-G-72 (Professional).
Should I get a heavy-duty rake -- or is that overkill using a 40 hp tractor?
These are my choices so far -- what else should I consider?
   / Need Landscape Rake Advice #2
I use a leinback 84in rake on my Bobcat CT235 (35hp) and also used on a 4120 Deere so I would a get a 84in if I were you. It handles it well
   / Need Landscape Rake Advice #3
I think mine is the KK YR-G-72 professional and its on a Kioti DK35SE HST. It works nicely with no problems. I put in a 3 acre lawn last year for my neighbors with nice results. Go as big as you can afford, they are not hard to pull behind your tractor. I got a 72" because of the stupid price that was on it, i couldn't pass it up.
If you get one ide advise the wheel kit, it makes the work a lot easier. I don't have wheels on mine but im thinking about putting some on it. . . . John
   / Need Landscape Rake Advice #4
Woods makes a great H.D. rake. I have a York brand and it is great, but pricey. Whatever brand you get, a wheel kit is a must have item.
   / Need Landscape Rake Advice #5
Get as heavy duty of one as you can afford. I too would get a 7 footer for your size of tractor.
   / Need Landscape Rake Advice #6
I have a six foot woods for my B2710 and it handles it easily. I would follow the others and go with the 84 unless you are maneuvering amongst a lot of trees
   / Need Landscape Rake Advice #7
I wouldn't go real cheap, but typically a landscape rake doesn't get into really heavy duty work. If it hits the proverbial "immoveable object" the spring tines just let it go. It's not like a box blade where it becomes a contest.
I bought a used Woods many years ago. It doesn't get a whole lot of use because it does the job quickly and then I'm done.
Definitely want the wheels with it!:thumbsup:
Where would I purchase a Woods or a York brand? Are these sold direct, through dealers, or retail?
   / Need Landscape Rake Advice #10
Don't know your specific wheel/tire setup, but tractor data puts the width at nearly 66". Definitely go for the 84 incher. If/when you fully index a 72 incher, it will no longer cover your rear track.
//greg//
LANDPRIDE RCR1260 - 5' ROTARY MOWER (A50459)
LANDPRIDE RCR1260...
2022 BOBCAT T66 R-SERIES SKID STEER (A50458)
2022 BOBCAT T66...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
2005 Bobcat S185 Skid Steer (A50490)
2005 Bobcat S185...
Shoreline Boat Trailer (A50860)
Shoreline Boat...
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
