Need L245 - L2201 ROPS Cross Reference
   / Need L245 - L2201 ROPS Cross Reference #1
CSH
Bronze Member
North Alabama, USA
Farm Pro 2425
After speaking with a couple of used equipment dealers in my area (who assured me the L245 ROPS would fit my L2201), I called the local Kubota dealer to order a ROPS. Of course, I had to place the order for a L245. Dealer said no problem, they would call me when it arrives. Shortly thereafter I had a message on my machine requesting the L245 variation (e.g., L245HC, L245Q?, etc.) from the identification plate that is riveted to the frame. They need the model variation to get the ROPS that fits correctly. The identification plate on my 2201 is gone. Anyone out there have any guidance on the 245 variations, the codes that will appear on the id plate, and what would most likely fit my tractor? You can see pics of the L2201 in the Zen-noh posts of this forum. Thanks in advance.
   / Need L245 - L2201 ROPS Cross Reference #2
CSH
Never knew there was more than one type of rollframe made for L245. Any that we have seen, have been all the same at the rear (square) axles that carry the ROPS. Our supplier manufactures only the one type ,which fits L245 and L2201 the same.In OZ we have several manufacturers of roll frames but I think each has only one type for L245. I cant see L245HC or Q or whatever making any difference as far as fitting a ROPS.
Good luck
   / Need L245 - L2201 ROPS Cross Reference #3
CSH, the L245HC is a hi-clearance offset design like the Farmall A or 140. As far as I know, all other L245's are standard design, so roll guard should interchange between them.
Tom
Thought I'd follow up on this for the archive. I spoke with the dealer again yesterday and there are 3 different roll bars for the 245. The DT (4WD version), H (high clearance w/ offset driver seat), and the F (standard 2WD). Mine is the F configuration. Don't know where he came up with "Q" in the voice message that was left the same day that I ordered.
   / Need L245 - L2201 ROPS Cross Reference #5
Hi CSH
Could you advise the difference between the DT or the F version. I would have thought the back (where the ROPS mounts) would be the same on these tractors. I can understand the H with offset seat may be different.
many thanks
BillK
BillK, no I cannot specify the difference between the DT and F. I am just passing along what the dealer told me. If I find out I'll be sure to post the details.
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
71059 (A49346)
71059 (A49346)
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
