Need JD 2155 wiring diagram
   / Need JD 2155 wiring diagram #1
JD15302155870
Bronze Member
Commerce, GA
My 2155 won't start with the key. I can crank it with a screw driver across the terminals on the starter. I think it has to be either the key switch or the safety neutral switch.
   / Need JD 2155 wiring diagram #2
I don't have a wiring diagram but I can tell where to find the neutral start switch which is probably the problem. Take out the bolts that hold the sheet metal on that the 2 gear shift levers protrude through. You'll find the NS switch under the cover. A lot of times all one needs to do is remove one or two aluminum shim washers and re-install old switch.
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
