Tim Berframe
Bronze Member
After much procrastination, I finally tackled the repair of the broken timing gear case. Thanks to those who responded with helpful advice. One must tear a lot of things apart to do this repair! I was afraid of getting the timing out of whack so took lots of photos as I tore things apart. I put everything back the way I found it and ( after learning the hard way about air bleeding a new fuel filter install) it runs again. However, after reading some posts here about operating rpm I have serious doubts as to whether the timing is correct.
Some folks say to run this machine above 2000 rpm. The green indicator on the tach is 2200 to 2400. I have never ran it above 1800. Any more and all it seems to do is get louder, vibrate more - no more power or speed. To run at 2300 rpm feels like serious abuse of the engine. This engine is a bear to start in winter even with inline heaters and powerful batteries and fully functional electrical systems. ( I live in Alberta. -20C is a normal winter day where nobody minds working outside. -35C is common and one sometimes must plow snow to get to work at these temps)
Before dismantling things, I pulled the glow plug from #1 cylinder so I could find TDC. I couldn't get it to stop exactly when rotating by hand, it rolls slightly past. The timing marks are not quite fully lined up at TDC but do line up a degree or two after TDC. The photo shows this position.
The manual for the 485 says advance angle of supply fuel/speed(before TDC) is as follows:
10+- 1/3000 with advance device
18 +-1 2800rpm
16 +- 1 2600 rpm
15 +- 1 2400 rpm
The photo shows the engine sitting at about 8 degrees after TDC when the timing marks are aligned. The scale only goes to 10 before TDC.
The three bolts holding the injector pump timing gear were barely more than finger tight. It appears that the slots are chewed up. I think maybe it has slipped and is now incorrectly positioned (but it is possible that it was just roughly machined).
Question: How do I determine the advance angle of supply? The timing marks confuse me because I would assume they would exactly meet when engine #1 is TDC.
How do I determine if my engine has 'advance device' ?
How do I determine the exact moment the injector pump 'fires' #1 ?
Tim
18 +-1 2800rpm
16 +- 1 2600 rpm
15 +- 1 2400 rpm
Tim
