Need info on B8200 & B7100
/ Need info on B8200 & B7100 #1
klm
Northwest MO
Allis D17 CIH D40, JD5310, Massimo MS50010
Looking at a B8200 4wd HST with 60" belly mower, appears to be in excellent shape, hour meter busted, I need some idea of what they are selling for. Also would like the good and bad of this model.
Also have the same questions on a B7100 4wd hst with 60" bellymower.
/ Need info on B8200 & B7100 #2
The B8200 has 19hp and the B7100 has 16hp. As stated before, the B7100 doesn't have power steering. Does the B8200 have PS? If you plan on using an FEL with it, you'll definitely appreciate it. The 7100 also does not have position control for the three point hitch. It's not a big deal but is handy for leveling and grading work. As a previous owner of a B7100 I can tell you it is a workhorse far beyond it's size and the only reason I traded up was due to the power steering/FEL issue. Other posters on this forum have the B7100 with the FEL and have been completely happy with it so..... the real decision is which one do you like!!!!
/ Need info on B8200 & B7100 #3
The B8200 is more tractor than the B7100 is, but as stated in another reply the B7100 does a lot of work for its size.
The B7100 does not have power steering; as I understand it power steering was an option on the B8200 (at least I've operated one that did not have power steering).
The B7100 is probably the longest production tractor in Kubota history, being produced from late 1970s (1976?) thru around 1998. The older hydrostat models had 4-lug front wheels while the newer models had 6-lug front wheels.
COOLING SYSTEMS: The B7100 has a "thermo-siphon" cooling system, meaning that it is a pressurized cooling system that has no thermostat nor water pump and relies upon fluid temperature differential to move the fluid around. It is a good and simple system, but a lot of engines have been ruined (including the one in my B7100) by adding more than 50% antifreeze to the cooling fluid and/or not pre-mixing the coolant mix. Excessive blow-by through the valve cover vent tube is on sign that the engine has been damaged by overheating (again, I'm speaking from experience; I didn't realize until after I bought the B7100 that the compression rings were bad and quickly got worse). I believe (but am not sure) that the B8200 has a normal cooling system with therostat and water pump.
PRICE: Without more knowledge of the shape of these tractors it would be hard to give an accurate estimate. MY OPINION (worth about 2 cents): A newer model (mid-1990s) B7100 HST in tip-top shape with mid-mower might approach an asking price of $6000; I think the B8200 was produced from the range of 1981-1988 or so and one in excellent condition would also probably be priced in the $6000 range. The problem with these higher prices is that if I were shopping for either of these in that price range I'd just go ahead and spend a little more and buy a new BX2300 and have a lot more tractor. Accordingly, I'd have to see either one in the $3500 to $5000 range in very good or excellent condition to avoid going the BX route.
Good Luck,
Kelvin
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A65563)
2021 Big Tex...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
2026 Electric Tricycle (A64194)
2026 Electric...
(15) Kinze 48 Cell Bean Plates (A65640)
(15) Kinze 48 Cell...
17.5X25 industrial tire on Deere articulated loader rim, Coal Valley, IL (A65640)
17.5X25 industrial...
