need info about forklifts
   / need info about forklifts #1
Anonymous Poster
Epic Contributor
Does anyone have any recommendations for a good fork lift (lift truck). I am very partial to Japanese engineering, so I am interested in gathering information about Mitsubishi, and Toyota lift trucks. I can't seem to find any forktruck forums on the net. Go figure. /forums/images/graemlins/tongue.gif
   / need info about forklifts #2
My neigbor has worked on lift trucks around 50 years hes still working on them every day at age73. He says a Toyota is a good lift but at a few years of age they start droppin parts like crazy. He works for a coffee warehouses fleet of them and after 2 years they go down hill. A mitsubishi is a good lift change the paint color and you have a Caterpillar lift. Thats also a korean lift truck that makes one for Cat that ls identical to one of of theres but its got red paint on it and has a lw resale whichs doesnt matter.
You can buy an older Hyster, Towmotor/Cat, Baker, Yale,Clark,Allis Chalmers for a few hundred dollars here. The little hard tire machines dont sell well here i have 3 in the shop with 2 of them for sale now. Id recomend any of the mentioned for business use just make sure that you have a good motor if its a Contenintal engine. Take care Taylor Lambert
   / need info about forklifts #4
Ben.......I make my living reconditioning used/off lease forklifts and for my money the toyota's are the way to go. I have several dealers I buy from and I always have customers waiting for used toyota trucks. I get machines that have been maintained through a lease maintence program which PM's the machines on a hourmeter basis. I don't usually get any toyota machines in with less than 5000 hours on them and most if not all need only cosmetic work to make them look and perform good as new. The toyota rep. says 20,000 hours on a machine is common and I personally saw a 1994 model at a trucking terminal with 33,500 hours still used on a daily basis. If you have any questions send me an E-mail and I'll help you with any info you need..........TOM
I've heard only good things about Toyota lifts, and I personally know what kind of quality goes into their cars/trucks. I was suprised to hear one of the replies indicating they were unreliable. I heard one other guy tell me that Toyota was bad about obsolecent parts.
I have done some calling around though, and have found a Nissan dealer and a Mitsubishi dealer that service my area. I am tempted to go with the Nissan lift, because the dealer has been there (selling Nissan lifts) for 15+ years. I have owned Nissan cars also and believe that their quality is a close second to Toyota.
Can anyone give the Nissan lift a good recommendation? /forums/images/graemlins/confused.gif
Thanks for all the replies! /forums/images/graemlins/cool.gif
   / need info about forklifts #6
I've had a couple nissan lifts as well as others powered by the nissan H-20 engine. The lifts were well built and their motors hold up well. As for mitsi.............Well.........."Go for the nissan"...................Enough said ????.....................Most larger dealers have a parts network ("unisource" for example) that is kind of "NAPA" for the forklift world.....They can get parts and service for most popular brands which enables the dealer to service several different brands as most large companies have several different makes of lifts running around their facilities but only want to call one repairman.................
Thanks for the input. Let me ask you one more thing please.
I've been riding around on hard tires for 5 years, and never really had any complaints. I am sort of thinking air tires would come in handy in certain instances. I am wondering about flat tires though. Are those tires pretty resistant to flats? I have always wondered how lift trucks can drive around salvage yards and such without getting flats. /forums/images/graemlins/confused.gif
I have also been getting along fine without side shift forks, but I'm thinking that I would never regret buying that option.
   / need info about forklifts #8
What is your lot surface??..........Pavement "ie" concrete, black top or chip/seal..........cushion tires OK........Loose gravel, uneven terrain, dirt, etc = air tires..........They make a solid tire to fit most air tire rims which eliminates all flats but ride quality suffers and they're quite expensive. The standard air tires for lift truck service are really heavy duty and unless you are around nails or metal chips they hold up well. You can always foam fill the air tires but the cost is life threatening.........As for side shift........it's like a pickup truck..........never had one .........you don't need it..........once you've had it you get used to it and won't do without it...........Tom
Thanks for the replies Tom. You're a good egg. /forums/images/graemlins/cool.gif
   / need info about forklifts #10
I didnt mean to sound down Nissan badly, just not alot of good ones here, most dealers here dont carry parts and it used to be hard for my neighbor to buy parts for them. I used to own a few of them for my shop but they had been reconditioned poorly. At a freinds scrap yard they have virgin rubber filled tires they get holes in them but self seal they loose alittle air but not enough to hurt and they have a good smooth ride. i just piccked up 3 Raymond pallet stakers with the sideshift and telescopic scissor forks for 145 dollars each all running with chargers. Take care Taylor Lambert
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
2013 International...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
