Front-End Loader Need Idea: FEL TB Caps 2 Not Gouge Garage Pad Taking FEL On/Off
   / Need Idea: FEL TB Caps 2 Not Gouge Garage Pad Taking FEL On/Off #1
Tom_H
Veteran Member
20 mi SE of Sacramento, CA-rural
Kubota BX2200
I posted the following in the Kubota Owning and Operating Forum. I am reposting here, in hopes that others will have ideas to contribute as well. I am posting a link below to the original post, so that all replies can be in the same thread.
I keep the BX 2200 and all the implements in the garage. If I leave the Markham tooth bar (5 teeth) on the FEL when removing the FEL, it gouges the concrete when removing and also when reattaching, so I take the toothbar off before removing the FEL. (My FEL front edge has to be at 20 degrees down tilt for removal.)
I know I could come up with something to quickly and easily cover the teeth prior to FEL removal so I don't have to take the TB off, but I figure someone else likely already has a solution.
Any ideas? Pics welcome!
Thanks guys.
Please reply at:
http://www.tractorbynet.com/forums/kubota-owning-operating/140305-need-idea-fel-tb-caps.html
   / Need Idea: FEL TB Caps 2 Not Gouge Garage Pad Taking FEL On/Off #2
Tom_H
If you have the holes drilled for the tooth bar in the forward part of the oval hole loosen the bolts slide it forward and it should flip in to bucket.
Then you only have the straight edge to deal with.
tom
   / Need Idea: FEL TB Caps 2 Not Gouge Garage Pad Taking FEL On/Off #3
How about laying down a piece of channel iron as wide as the bucket and setting the edge w/teeth on that?
3 pt Finishing Mower (A50514)
3 pt Finishing...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
