need honest info on pt 425
   / need honest info on pt 425 #1
trailertrash
Bronze Member
Clark Co. Ohio
1961 ford 971
I am interested in purchasing a pt 425 with canopy, bartires, 60" deck 48" tiller, light bucket, snow blade (60") and mini hoe, I am a large man around 6'4" 350lbs, I am wondering if a man of my size will fit this tractor and if i have pretty well covered the basic needs for this pt for a 2 acre home. What other implements would you experienced users recommend? What disadvantages have you encountered with a pt 425 versus a regular tractor ie Kabota, John Deere?
   / need honest info on pt 425 #2
I'm 6' @ 205 lbs w/ size 13 shoes and a 34" inseam. I've operated up to 5 hour stretches of heavy loader work. I was very comfortable. In winter, with large snow boots on, the footwells are a little tight, but not bad at all.
Basic needs for 2 acres, at least to me, would be 60" mower and the light material bucket, that's it /w3tcompact/icons/smile.gif Everything else is just gravy /w3tcompact/icons/laugh.gif The light material bucket is my most used implement. The only other attachment that you are getting that I can comment on is the power angle snow plow. It works great. Especially when you have to pile up the snow. Being able to lift the plow and tilt it like a bucket works great up to about 4 feet high.
The pallet forks are pretty handy and not too expensive. I use them about once or twice a month(used them this morning to load an old snowmobile trailer onto my carhauler trailer). You might want to consider them.
As far as disadvantages as compared to a conventional tractor, they are two different beasts. Very hard to compare. In my opinion, the Power Trac PT400 series is like the ultimate small landscape and estate maintenance machine. The implements can be changed so rapidly that no conventional tractor can even come close. Have you seen my videos on the 15 second implement change(if not, click on my signature at the bottom and go to the videos section of my web page)? And you don't have to get off the tractor unless the implement is powered. That adds about another 15 to 30 seconds, as all you have to do is hook up two hydraulic hoses. The low center of gravity and turf friendly full time 4 wheel drive work well together. It is very hard to even intentionally scuff up the turf.
A comparably sized conventional tractor would be much better for plowing a field. Not that the PT couldn't do it... is is just that plowing backwards would just be a pain.
The 400 series will not lift high enough to load a pickup truck. Most conventional tractors will. I knew this before I purchased, so I was not surprised or disappointed. I purchased a car hauler trailer and can load it just fine. I am getting rid of my pickup truck and tow the PT on the trailer with my full size van with no problems, so I no longer need a truck.
It is a gas engine and I love it. It is VERY loud. It starts well in very cold weather. It uses about 1 gallon per hour at full throttle, which is where I usually run it anyway.
There is no dealer nearby. So what /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif I am good with mechanical stuff, the engine is covered by a Kohler warranty and Power Trac has excellent phone support and can ship parts rapidly, should you break something... We have an excellent small engine parts store here and I can get Kohler filters, service manuals and parts. The tractor is so simple that there is little to maintain.
Maintenance. Every 8 hours you have to grease it up. There are six bolts that have to be removed to get to the foot treadle linkage. It is kind of a pain, but once you do it, it isn't too bad. 8 hour maintenance takes me about 15 minutes if I don't wash the tractor.
I would say, if you are going to do more agricultural work, get a conventional tractor. If you are going to do typical homeowner, small estate owner or landscaping work, the Power Trac PT425 is more versatile, faster, easier to operate, easier to transport, easier to learn and probably safer as there are less controls to mess with and mix up.
The front mounted implements cannot be beat for visibility. Mowing is extremely easy and you don't have to look down like a mid mount mower or behind like a rear mount. Also, you can stuff the front mount mowers under shrubs and trees about 3 feet. You can't do that with a mid mount mower.
The thing is built like a tank. No sheet metal anywhere. Plate steel everywhere. Wire brush and lightly sand any scratches and touch up with spray paint. No need to baby this beast, it can take it /w3tcompact/icons/laugh.gif
With that said, the JD41xx series, Kubota BX series and NH boomer series are all fine machines that you would not be disapointed with either. I don't want to come off as disrespecting the owners of these machines. I am just really satisfied with the machine that I decided to purchase and attempted to list the advantages that I see.
What part of the country do you live in? There may be a Power Trac near you.
I guess I did'nt phrase my question properly,although two good points have been answered -size and loading over a pu-I have about 100' of 12" culvert to install and about 90-100 ton of gravel to put in my driveway plus I bush hog 5 acres every 2 weeks and mow 4 1/2 acres every week.Some of what I mow is so steep that I use my trusty 12hp wheelhorse so I can sit on the uphill fender(still rolled it once last year) Now I have decided that I'm too old for this kind of fun. So I'm looking for something Safe to mow inclines but I need something to be able to dig ,carry ,till,lift, push snow and dirt .Since I don't seem able to win the lottery I need to be price concious.I have a ford 971 which is a good tractor but it's too big to mow a yard , good for bushhog bad on inclines and fel because it' a tricycle front end (talk about your pucker factor)The PT looks to be a good choice just curious about the trade offs I guess and the cockpit size I tried some of the cuts and they were too small for me , really liked some of them just did'nt fit.
To moss road I live in mid ohio,and your web site is great you should lease it to PT
thanks for some good info
   / need honest info on pt 425 #5
MossRoad
Your post is a gem, you continue to reaffirm the reason I will be getting my PT this coming spring.
PJ
   / need honest info on pt 425 #6
I'll try and make a shorter reply this time /w3tcompact/icons/laugh.gif
I move 90 tons of moondust(granulated limestone) about 250 yards in 5 hours. Gravel is lighter per bucket load. Shouldn't be a problem.
I have the 48" brush hog on my PT425. It is a powerful beast, but I only do trails, no acreage. I don't have a guess as to how long it would take to do reqularly cut fields. Front mounted brush hog is superior to rear, as you drive over a freshly cut path, it is easier on the tractor and operator has no stiff neck form looking backwards all day.
As far as mowing hills goes, there has been some reports here about not having enough power to run the 60" finish mower up steep hills. They went to the 48" finish mower. I have never mowed hills with my 60" finish mower, but I have brush hogged them up and down only, not across. It did a fine job. Also, some people have had trouble side slipping on slightly damp turf. Again, I just read it, I haven't experienced it.
   / need honest info on pt 425 #7
I have a pt422 with a 48 inch mower, tiller and small bucket. I have had it for two and one half years with 370 hours of use on it, and my wife and I just love it , and we have had no problems with it. We mow about 5 acres of hillside lawn with it weekly in about 3 hours. My wife does most of the mowing . Some places we mow across slope are a little over 20 degrees with no problem. Mowing up and down these slopes it could use more power. I believe this machine would be hard to roll over as it is low and wide. The tiller works real good if you don't have a lot of stone.
As to your being comfortable using this machine you would probably have to try it, I am 6' 2" about 210 pounds size 12 shoe and I have no problem.
There are a lot of attachments I would like to have but I would have limited use for them .
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
23018 (A55758)
23018 (A55758)
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
