Need Help
   / Need Help #1
Timotheious
Speedex 1630
I have a Speedex 1630 with a 16 hp cast iron Briggs and Stratton motor. My problem is it is hard to start and it will not rev up. It runs at a constant low rpm and doesn't change under a load. I've tried a new carburetor and switched to electronic ignition. But I still have the same issue. I cannot get it to rev up. It has 16 hp at 3600 rpm, but I can't even get close that. I'm pretty sure it is controlled by an internal governor and I don't think it is working. Any and all assistance would be greatly appreciated. I'm ready to do a tear down and complete overhaul, but I'd rather try to resolve the issue because it still has good compression. I'm not sure if it is gas related; timing; magneto (coil). I'm leaning toward timing, but not sure. Thanks in advance for any suggestions
   / Need Help #2
What happens if you manually move the linkage right at the carb?
Doug in SW IA
   / Need Help
It dies. I had the valves reseated a couple of years ago. Not much of an improvement. Put a new starter and switch on a couple of months ago. It has a lot of power for all the higher the rpm's will go. I would like to work a little faster than just a crawl or so it seems. reminds me of a 2 cylinder johndeer. i am going to move the timing around little bit tomorrow. Thank you for your response.
   / Need Help
Flywheel key was sheared. Backfire through the the carb. and muffler while cranking was a good sign. Timing seems too far advanced now. Guess I'll play with the magneto mount to see how close I can get it. I should rebuild it and get it over with.
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
